Remote Start question for manual transmission
Old May 7, 2009 | 06:55 AM
djfrog2001's Avatar
Default Remote Start question for manual transmission
I know that it is possible to bypass the clutch safety switch (not sure what exactly it is called on a eclipse) to allow for installing remote start on a 5-speed but is there a way to set it up so that the remote start wont work unless the shifter is in the neutral position?
Old May 7, 2009 | 08:29 PM
im sure it must have to be wired in that way, otherwise it wouldnt be very safe, haha. I bet an install shop could tell you that one
Old May 8, 2009 | 11:28 AM
djfrog2001's Avatar
i know it's wired so that the clutch has to be pushed in to start the car but it doest matter what position the shifter is in. I also know it is fairly easy to bypass the clutch switch. What I am wondering is if you can bypass the clutch but require that the shifter be in neutral to start the car.
apw5060
Jan 16, 2012 12:16 PM
RoadCrasher
Jan 12, 2010 01:08 AM
n5926g
Mar 17, 2007 11:10 AM
soloRider
Oct 28, 2005 10:32 PM
dariddler
Oct 12, 2004 02:35 PM
