Runnin Lean??
Old Apr 8, 2006 | 01:50 PM
a2rht930's Avatar
Default Runnin Lean??
p0170 Fuel Trim Malfunction. What causes it,and how do I fix it.
Old Apr 8, 2006 | 05:22 PM
Default RE: Runnin Lean??
could be one of two thing i think. 1) there is a leak and the cause could be the valve cover gasket or 2) You could have bad air flow through your MAF. Those are just a couple. there may be more. Is this the only code that your getting?
Old Apr 8, 2006 | 11:27 PM
a2rht930's Avatar
yep
Old Apr 9, 2006 | 01:13 AM
Joel_CA's Avatar
Check for a manifold vacuum leak somewhere or some other source of unmetered air.
Joel, CA
Old Apr 9, 2006 | 03:13 AM
Sanguinius's Avatar
Check your intake piping for cracks or rips, loose clamps. cleanliness of the MAF as well as the air filter. Let us know what you find.
Old Apr 10, 2006 | 12:46 AM
eclipsed4u's Avatar
also get the cat and the o2 sensors checked(if you still have a cat). faulty readings from bad o2 sensors can make the ECU think that there is a problem with the a/f ratio.
Old Apr 10, 2006 | 12:50 AM
ORIGINAL: eclipsed4u
wont that ussually throw another code in there too though. Ussually i think you will get the fuel code but you will also get the 02 code for bank 1 or bank 2....right?
Old Apr 10, 2006 | 01:04 AM
eclipsed4u's Avatar
ORIGINAL: TheEngineer
sometimes, yes. but i know that there is not a code for a bad cat, and it also throws similar codes. when my cat went bad, it threw P0171 and P0174 codes.
Old Apr 10, 2006 | 01:13 AM
ok ill agree on the cat but not the o2's being a possible problem. But because its only throwing that one code i am going to still guess a leak
ilb2fast4u
Nov 1, 2008 07:07 PM
asphalt_pimp
Jan 29, 2008 09:37 PM
asphalt_pimp
Oct 17, 2007 10:15 AM
awd92tsi
May 29, 2007 12:51 PM
hosrom
Mar 31, 2007 08:28 PM
