Smoke from oil cap???????
Old May 15, 2006 | 11:43 PM
  #31
paintballproam's Avatar
Default RE: Smoke from oil cap???????
Yeah I really want to get this running
Old May 15, 2006 | 11:49 PM
  #32
Sanguinius's Avatar
Well do that stuff and let me know what happens. We'll get it running. It may take a bit of frustration and troubleshooting but we'll get it. Biggest thing is cleaning the CRAP outta it. That's what you need to start with.
Old May 15, 2006 | 11:53 PM
  #33
like i said, this is my first time starting it, the last thing that happend before i got it was a head gasket
Old May 16, 2006 | 12:43 AM
  #34
NubianSithLord's Avatar
It has a new HG?
Sag is right clean fuel needs to run thru that car. I had a 240SX sit for a few years in my Moms back yard and when I finally started it she sputtered bad and the oil was like sludge. I filled up with high octane plus injector cleaner. After I started I just popped her into 1st and drove slow for about 10-15 min only in 2 and 3 and she drove fine. I did eventually get a engine flush to clen that oil. Which BTW did not come clean until about 9000m 3rd oil change before it was that light brown color we all love.
So when U start it just ease of the clutch and ride around the block a few laps and U should be good!
Old May 20, 2006 | 03:43 PM
  #35
Ok i just put in accel wires, ngk iridium plugs, optima red top battery, 130amp alternator and a breather filter on the side of the valve cover. I went to start it ( i was jumping it with another car just in case the battery was dead) And it wouldnt start but would turn over and stuff, then i looked at the breather filter and there was quite a bit of smoke comming out of it ( looked and smelled like burnt oil). I took the oil cap off and there was some smoke, it smelled awful. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 20, 2006 | 03:44 PM
  #36
and royal purple 10w30 oil and new bosch filter
Old May 20, 2006 | 08:03 PM
  #37
dreamz's Avatar
does anyone think it could be his piston rings ? did u check your compression but i really think it could be your timing maybe your firing in you intake stroke while oil leakin threw your rings ?
Old May 20, 2006 | 09:37 PM
  #38
took off the valve cover and there was a like a half circle shaped thing right near the oil cap, there were other ones like for something to sit in. like 2 half circles side by side. Get what im trying to say? anyway on the one by the oil cap, one side was bent down so i straightend it before i put it all back on with a new gasket. But now i have no spark ( SEE MY NEWEST THREAD ) [>:]
willdue
May 30, 2007 11:27 PM
blamesociety
Nov 2, 2006 08:45 PM
BrunoBoy650
May 31, 2006 07:39 PM
2001EclipseGTnub
1st Generation
Jan 16, 2006 10:44 PM
jap901
Jul 24, 2005 10:05 PM
