Speed Sensor Wire
Old Mar 5, 2006 | 07:18 PM
imtalkintou's Avatar
Default Speed Sensor Wire
I recently got myself a nice greddy full auto timer, everything works that i have hooked up, the only thing that i don't kno what to do with, is the speed sensor wire i'm suppose to attach to my car, my question is this, what color is the speed sensor wire, and where is the easiest spot to find it. I have a 98 spyder gs-t. I even called the dealer and they don't kno. I NEED HELP.
Old Mar 5, 2006 | 07:20 PM
Default RE: Speed Sensor Wire
how would a dealer not know, the best thing to do is go to autozone and look in the haynes manual, they should have an ECU wiring diagram in there that will tell you what color and where the wire is. Then you can just tap into it.
Old Mar 5, 2006 | 09:31 PM
My93EclipseGS's Avatar
I agree with Engineer get a Haynes manual they have good wiring diagrams for the ECU. FYI the speed sensor itself is located on the top of the transmission for a M/T and in the speedometer for an A/T
Old Mar 5, 2006 | 10:14 PM
i have the haynes manual and it doesn't show it in there. and the people at the dealer even looked at the guide they have which from what i understand is even more in depth than the haynes manual. still lost....
Old Mar 5, 2006 | 10:40 PM
Is your car an Auto or Manual Transmission? I am at work right now, when I get home tonight I will look and see what I can find and point you in some direction.
Old Mar 6, 2006 | 12:19 AM
manual transmission
Old Mar 7, 2006 | 05:46 PM
still lost. anyone??????????
Old Mar 7, 2006 | 11:55 PM
Well the easiest spot to find the speed sensor is on the transmission. As for the wire I haven't a clue where it is inside the car itself.
Old Mar 9, 2006 | 01:22 AM
Ok sorry for the delay. I found that if you pull the ECU connector out the Speed Sensor wire will be the one Numbered 19. You can tell the number cause if you are looking at the connector the number 1 pin is the top left. The bottom left pin starts at 14. Hope this helps.
Old Mar 17, 2006 | 06:17 PM
i'll have to check that, just need to wait til it gets a little warmer cause i'm to lazy when its cold. i'll tell ya if it works. thanks much
jthorn75
May 23, 2012 02:40 PM
eugenexyu
Aug 30, 2010 07:52 AM
sickend
Sep 12, 2006 06:25 AM
5Tizzle
Aug 14, 2006 12:07 AM
faded2
Jan 19, 2006 08:43 AM
