Sputtering
Old 10-02-2006, 01:12 PM
burnmyeyes's Avatar
Default RE: Sputtering
The mass air flow sensor. It is the assembly that measures the air entering the engine.
  #22
Old 10-02-2006, 01:28 PM
that could be the problem with mine too. Seems like in the morning when I'm warming up the car, The idle is weird and I placed my hand by the air intake filter, it feels sucking huge amount of air into it. When that happened, the rpm going lower and slowly rises to 1500 and the car would go normal.
  #23
Old 10-02-2006, 01:55 PM
1500 isnt a normal idle
  #24
Old 10-02-2006, 01:57 PM
what I meant was, it will go up to 1500 and come back down to 800 and stay between 800-950
It's just the part when it makes weird suction noise, the car idle low like 600-700 and slowly rises to 1500 .
  #25
Old 10-02-2006, 02:04 PM
if its an air noise then its probably a leak.
  #26
Old 10-02-2006, 02:08 PM
do u think it's air leak? I just ordered IAC
  #27
Old 10-02-2006, 02:17 PM
well your also saying it only does it when you first turn the car on or always when you go back to a stop
  #28
Old 10-02-2006, 02:19 PM
only happened when the car temperature really low.
  #29
Old 10-03-2006, 03:32 PM
I finally found the sputtering problem with my car. It's the fuel filter. Still original stock fuel filter from 1995. I got it replaced and runs like a champ. THanks
  #30
Old 12-01-2012, 01:41 AM
stevenseclipse's Avatar
So i know this thread is like 6 years old. But if you guys are still here please help me lol. I have a 1999 eclipse gs, the kid i baught it from had a turbo on the car, well before i baught it he took it out, the car has a rough time idling. when i first got it the CEL was on so I took it to get scanned. It threw 3 codes, 1st was p1390 which come to find out is a timing code, "timing jumped 1 tooth or more"
i took the car to a few mechanics and they all said the timing is at the most a 1/4 of a tooth off if not perfect. 2nd code tps still need to replace. 3rd code MAF still need to replace. but my question is if they had a turbo on the car before and they took it out could the ecu be throwing timing codes cause its still tuned for a turbo? theres also a missfire in cylinder 1 code. i changed all the wires and plugs but to no avail. Mind you guys the wiring on this car is a monstrocity, lol. i wish i could restore it to its glory days.
bobbytomforde
12-24-2005 12:38 PM
eclipse27
12-06-2005 03:24 PM
90galant
09-29-2005 03:17 PM
WGONFAN
05-04-2005 05:40 PM
girlgetter
06-23-2004 08:05 PM
Quick Reply: Sputtering
