stalling/not starting
ok guys. i recently bought a used 95 gs from my relative and it was doing good for a while. then at random times the car would just die. no sputter, just stop running like i turned the key off. whenever it did this the oil light would come on. sometimes it would start up like nothing happened a couple minutes later or a day later. but it usually stalls right before i come to a stop. i changed the fuel filter, fuel pump, and did a full 5-30 sythetic oil change. changing the filter seemed to work for one day and then changing the fuel pump seemed to make it run much better, but i did it again one week later while i was driving down the highway. after the oil change it really semed to have gone away. almost to the point of me forgetting about it,.... and then it did it again. my father says it might be the fuel pressure regulator, ive already spent over 200 bucks on things that didn't fix it... ive tried finding a solution somewhere but none of them that mention the stalling mention the oil light. thanks for the help
