lancer not starting
Old Jan 8, 2008 | 06:33 AM
mammikoura's Avatar
Default lancer not starting
basically it goes like this.
I try to start the car and the starter seems to work fine.
The engine gets very little rpm, maybe like 200 or 300 and then after a second or two the engine stops completely.
Check engine light is on, but it has been on for quite a while, and the car has been working fine before.
Spark plugs have been changed recently.
Any idea what's wrong?
ohh, and it's made in the year 1990, 1.5l engine. If there's any other info you need just ask.
Old Jan 8, 2008 | 10:09 AM
BEAT's Avatar
Default RE: lancer not starting
must be the battery, solenoid,starter,cables and voltage regulator.
Old Jan 8, 2008 | 10:12 AM
BEAT's Avatar
When it start trade it in with a newer car like Evo or Lancer or Mirage
Old Jan 17, 2008 | 10:05 PM
repins's Avatar
most likely it could also be the alternator cause if that is bad your battery would charge it and if the battery is basically **** then it would die after a few second check everything under the hood all the fluids and also the main stuff as in alternator starter battery seliniods timeing belt everything good luck and by the way get a evo or something new I am once I have this one paid off
2010Lancer
Jul 6, 2012 08:46 AM
monkeybumburning
Sep 18, 2006 12:59 AM
1.8Underdog
Jul 15, 2006 04:23 PM
bekahu410
Aug 20, 2005 12:34 AM
Nubian QT
Oct 9, 2003 12:09 PM
