SUNROOF!!
Old May 14, 2007 | 03:04 PM
The_Crow's Avatar
Default SUNROOF!!
ummm it leaks i dont know if its the seal or if the drain is clogged. It only gets wet on the drivers side seat (not the back part just the butt part) and the drive side roof. only does it in heavy rain. now if it is the drain then where is it and how do u unclog it.
Thanx
Old May 14, 2007 | 03:12 PM
Dusty Eclipse's Avatar
Default RE: SUNROOF!!
Likely to be the seal... waht year is it?
Old May 14, 2007 | 03:16 PM
The_Crow's Avatar
98 gs
Old May 14, 2007 | 03:27 PM
If its hot and dry where you live... Id put money saying its the seals... keep in mind, theyre pretty much 10yrs old. Rubber dries out after like 5...
Old May 14, 2007 | 04:30 PM
silvercoupe97's Avatar
Try to blow out the drain holes first. Take compressed air and blow them out, you'll see them when you open your sunroof.
Old May 14, 2007 | 07:40 PM
bras_33's Avatar
If there is water in the hatch area where the seals are its the drain. I found out the hard when it was pouring, and found water where my spare was. Good luck
Old May 15, 2007 | 08:30 AM
RCJr9186's Avatar
my 99 gs did it also. it's the drain. get a compressor and see it that does the trick, if not, get a cloths hanger... that's what worked for me.
jthorn75
Jun 4, 2012 04:18 PM
MrJayDeeOne
Aug 23, 2007 03:58 AM
Kdani
Sep 26, 2004 07:19 PM
iceyman
Nov 2, 2003 06:26 PM
tjrcs
Oct 7, 2003 04:28 AM
