tachometer on talon....please help!!!
Old Jan 24, 2008 | 07:22 PM
talontimmy's Avatar
Default tachometer on talon....please help!!!
ok so i have a 1996 talon esi and i bought a 5 inch autogage tachometter with shift light from autometer...what confuses me is i havent found the wire that u tap into for the actual tachometer reading....it has been said to be on the coil but i tried 2 wires on the coil and both of them got me a reading but when i reved the engine and the needle only goes up to 2000 rpms and like like twitches at idle...can someone please show me the proper wire to tap into....i am so lost...and im sort of a beginner with this performance stuff.....thank you
Old Jan 24, 2008 | 09:29 PM
RCJr9186's Avatar
Default RE: tachometer on talon....please help!!!
you probably won't find many if any people on here w/ an aftermarket tach. . .
Old Jan 25, 2008 | 06:47 AM
you have to find the rpm wire comming out of the ECU. There are a few different pinouts but the wire color is always the same. It should be a white wire with brown squaresonthe ecu (which is located in the front driver side in the engine bay) Just splice it in there. Sometimes on some models the wire may be a solid white but check for the brown squares first
Old Jan 25, 2008 | 08:57 AM
talontimmy's Avatar
ok i will try it...are u sure that those are the correct wires on my 1996 talon non turbo
thank you
Old Jan 25, 2008 | 10:24 AM
yup definitely
Old Jan 25, 2008 | 04:00 PM
talontimmy's Avatar
i got it thanks to you i really appreciate it
Old Jan 25, 2008 | 07:49 PM
no problemo
Old Jan 26, 2008 | 12:10 PM
darknigh7th's Avatar
just out of curiosity, why do you like, have, an aftermarket tach? they don't make you faster, and they don't make you look cooler... just wondering.
Bugly
Aug 31, 2011 09:20 PM
sethdakine
Sep 29, 2010 10:34 AM
eclipsekilla
Dec 19, 2008 12:25 AM
m3kgt_99
Mar 7, 2006 01:11 AM
unknown_owner
Nov 23, 2005 02:16 PM
