taking out engine
Old Jun 15, 2006 | 05:52 PM
bagz's Avatar
Default taking out engine
can i drop it to the floor with a jack or do i need a hoist? and how hard is it to take out?
Old Jun 15, 2006 | 10:30 PM
Sanguinius's Avatar
Default RE: taking out engine
Why are you dropping the engine? What work needs done?
Old Jun 16, 2006 | 01:06 AM
DixonsGst's Avatar
most def need a cherry picker (hoist).
Old Jun 17, 2006 | 01:44 PM
slvr_eclipse's Avatar
having a car hoist is definetly the easiest in my opion. if you have one all you need to do is disconnect all wire harness from engine and all the lines and such. unbolt all engine mounts and the struts from the strut towers with the car on the ground. Then just hoist the car up very slowly and carfully and you have suspension, engine, and tranny all out at easy access. Otherwise you need a cherry picker and that you have to only remove engine. If I understand what your asking about the jack you'd never get the car high enough to drop the engine from the bottom side.
Old Jun 17, 2006 | 04:51 PM
5Tizzle's Avatar
if youve never taken it out, its actually a huge feat to conquer. you have to take so much **** out, that you almost dis-assemble the entire car.
ive been working on just dropping just the trans out for like 4 days now. im almost there, but its not easy. in every other car ive had, taking the transmission out was a simple unbolt and drop procedure, but carmakers nowadays dont give a **** about anyone working on the cars. they just have to pump them out, and make profit.
Youll probably want a cherry picker, just because its easier to catch things that are still attached to it, when youre pulling it out, like some kind of wires or something.
Old Jun 18, 2006 | 01:08 PM
93eclipsegsx's Avatar
i took my motor ot of my car with the help of 2 other people. we just lifted the motor and carried it over and put it on the floor. i didnt really care what i did with it because i was swapping a 6-bolt into it. wasnt that heavy.
Old Jun 18, 2006 | 02:49 PM
5Tizzle's Avatar
ORIGINAL: 93eclipsegsx
You are a manly man.
Old Jun 18, 2006 | 03:09 PM
not really. i was inside the car and 1 friend was at the front of the motor(timing belt side) and another where the turbo wuold go and lifted it out. i got out of the car and lay'd it on its side.
Old Jun 18, 2006 | 07:55 PM
5Tizzle's Avatar
ORIGINAL: bagz
okay, i just got the transmission out of my car, and after looking at a couple things, it would be possible to drop the engine down to the floor, if you dont want to do it the crane way.
Lil Evo
Aug 14, 2006 03:32 AM
EMonz57
May 22, 2006 10:03 PM
blk beauty 3kgt
Mar 29, 2006 02:28 PM
Atownprepy99
Oct 4, 2005 07:21 AM
