CLUTCH PEDAL down at floor_Help me be more informed taking my car to mechanic
Old Mar 24, 2006 | 11:58 PM
blk beauty 3kgt's Avatar
Default CLUTCH PEDAL down at floor_Help me be more informed taking my car to mechanic
Hello,
I am new to this forum, so I hope some one out there will be able to help me with some detailed information about my car's problem.
I have a 93 3Kgt SL, with 85K miles on car. I have kept this car in primo condition, with regular maintenance, etc, but last week I went to drive car and the clutch pedal was down to the floor. I tried pumping pedal with engine off and also with engine on, and it's just dead, right near bottom of floor board.
I opened hood, got out owner's manual and looked at all the resoivors and they all look good, although one was at the min. level. I could not find the resovior that was suppose to be near the engine wall slightly down below. Now, the plastic on the resoivor that had the cap REPLACE WITH DOT 3 or 4, I could not open, it was too tight, and the plastic was kind of dark, so I am not exactly certain if it is completley full. It appears so from the outside.
I checked the floor of garage, and there isn't any fluid leaking out onto floor.
In any event, even if I could find the clutch resoivor that is suppose to be near the engine wall, I am too short to reach it, and have to have the car towed to a repair shop.
FIRST: What do you think the problem might be?
SECOND: How much should this cost to repair?
THIRD: What kind of warranty should they offer on this?
Any help would be greatly appreciated, so I don't get taken advantage of. If any one knows of any great mechanics in the bay area, pls let me know.
thanks all.
Old Mar 27, 2006 | 03:51 AM
alan92rttt's Avatar
Default RE: CLUTCH PEDAL down at floor_Help me be more informed taking my car to mechanic
Check the carpet under the peadels and see if their is any sign of a fluid leak there. If so your clutch booster may have gone out.
[url]http://stealth316.com/images/mastercylinder.jpg[/url <-- shows wherer to put clutch fluid
Old Mar 28, 2006 | 11:26 AM
m3kgt_99's Avatar
Mine was because of internal leak of the slave cylinder. It could have been rebuilt, but I just bought a new one for $50.
Clutch booster??? I have never heard of that...
m3kgt_99's Avatar
But I obviously saw brake fluid leaking out so...
Old Mar 28, 2006 | 11:54 AM
alan92rttt's Avatar
I forgot, the booster is for the AWD trans only.
Old Mar 29, 2006 | 02:28 PM
THANK YOU so much for that image of the clutch master cylinder. How do I get the cap off? I did see that under the hood, but that metal line that goes over it was too tight to move, so I could not get that cap off. That is showing fluid to the minum line, but I assume that the fulid level at min, would be sufficient to keep the clutch pedal working fine, so it is probably now a leak.
How much should I expect to pay to get his fixed?
thanks for the help!
Thirdorb
18
Feb 21, 2008 06:45 PM
wicked2407
Oct 25, 2006 06:07 PM
koodalgo
Mar 28, 2006 12:07 AM
Angel_408
Mar 1, 2005 05:20 PM
jfvalejandrino
Jun 8, 2004 06:07 PM
