Timing for a 4G64
Old May 5, 2006 | 03:21 PM
killzzz1's Avatar
Default Timing for a 4G64
I just changed the belt on a '97 spider with a 2.4 4g64 in it.
The manual says to check the counter-balance through the block plug
using a screwdriver.
My motor has 2 little holes, about 5mm deep and a plug to the water jacket.
Where is this plug to chck the counter balance shaft alinment?
Thanks
Old May 5, 2006 | 08:45 PM
93eclipsegsx's Avatar
Default RE: Timing for a 4G64
i think its right where you balance shaft is, it should be by little belt that comes off of the crank. if you dont get what im saying just say it and ill go take a pic.
Old May 5, 2006 | 10:30 PM
killzzz1's Avatar
Yes please take a picture when you can.
I think I see what your talking about.
I was confused from the picture in the manual as
I was looking on the side and not on the front of
the motor.
Thanks so much for the help.
***********No, that was the oil punp.
Still do not see what your talking about.
marshmallow746
Jun 10, 2022 10:20 PM
89Vanman
Jun 21, 2014 02:23 PM
8000RPMS
Aug 30, 2007 05:49 AM
bigguy6f4
1st Generation
Jul 9, 2007 05:45 PM
nadeemr
Feb 29, 2004 12:17 AM
