Timing belt
Old Jan 17, 2005 | 04:11 PM
baker_sk8er37's Avatar
Default Timing belt
How hard is it to change the timing belt in a eclipse because its about that time
1995 eclipse gst
Old Jan 20, 2005 | 03:53 PM
vertstanggt's Avatar
Default RE: Timing belt
It's a fairly involved job, mainly cuase of the space restrictions. If you had it out it wouldn't be that bad. All depends on how comfortable you are with doing it and if you can put the car up for a little while to get it done. Look into it, buy a workshop manual and decide if it's something you want to do. I'm lucky, I checked mine out a while back and it looks in excellent condition and was probalby replaced by a previous owner.
Old Jan 23, 2005 | 11:25 PM
DSMTalonAWD51's Avatar
the eclipse timing belt is not a fun thing to replace. i do all the work myself on my car but i dont mess with the timing belt. if you've never done it before the tiniest mistake can destroy your engine. also, like vert said there is limited space and a lot of things need to come out to replace it.
Old Jan 25, 2005 | 05:20 PM
Some garages, depending on the car, will actually pull the engine to do work on the front end cause with the facilities it's easier that way cause it takes you so much less time to do the work when you can actually move around it.
judien
Mar 9, 2018 03:41 PM
marx88
Jun 30, 2011 03:54 PM
8000RPMS
Aug 30, 2007 05:49 AM
agallardo
Oct 29, 2006 11:33 AM
shawnharper
Jan 31, 2005 03:30 PM
