transmission problems
Old Apr 3, 2006 | 09:34 PM
B.e.R.a.T's Avatar
Default transmission problems
I start having problems shifting gears. sometimes I need to let go the clucht and push it again to shift gear. I can't come up with anything is it a tranny or a clucht problem guys please i need some opinions.
Thank a lot
Old Apr 3, 2006 | 09:55 PM
Sanguinius's Avatar
Default RE: transmission problems
I have that problem once in a while when trying to shift into reverse with my Sentra. It's an '03 with 60K on the clock. Might try adjusting the clutch see if that helps at all...
Old Apr 12, 2006 | 11:39 PM
spazzman28's Avatar
have you tried to blead your slave silender thats what it sounds like to me
Old Apr 13, 2006 | 12:33 AM
estraw's Avatar
spazzman28 Date 4/12/2006 9:39:04 PM
if that doesn't work, you may need to replace the clutch master cylinder or slave cylinder, could be either one. that happened to me a month after i bought my car and spent no more than $100 replacing the parts. just MAKE SURE YOU BLEED IT when you finish
jp2000
Jan 1, 2012 05:21 PM
94 Mitsu Eclipse
Dec 20, 2010 06:59 PM
kandy eclipse
Dec 16, 2005 06:58 PM
bfunk
Aug 1, 2005 05:21 PM
99eclipse
Dec 2, 2004 04:11 AM
