Tuning w/o wideband
Tuning w/o wideband
Ok, I had an SAFC installed on my vehicle. I am running 650 inj. I am not installing my wideband right now, but I need to get my car running. Can I still tune the car fairly well just off the SAFC w/o the wideband. I read in some threads that it is doable. But I wanted to ask what problems I might run into if any.
Thanks
Thanks
RE: Tuning w/o wideband
650 inj
16G EV III
SAFC
Greddy FMIC
walbro 255
AFPR
ported exhaust manifold
1g bov
apexi n1 3in exhaust
MBC
boost gauge
wideband (not installed)
some other stuff
Dammit man, I really need to get my car running.
Got links to those road race startup tunes.
16G EV III
SAFC
Greddy FMIC
walbro 255
AFPR
1g bov
MBC
boost gauge
some other stuff
why not just install it. It shouldnt take very long, unless your just waiting to have a bung welded or someone. I mean with a pocket logger you could do it as well, but you really need a wideband. But here is a couple of maps from RRE
2G Turbo
16G Turbo, RSR Cat Back, RSR DP-no cat, Filter, 17psi, Front Mount I/C, Denso in tank pump,550cc Injectors, Side and Lower honeycombs out, Adjusting screw backed out flush
Low Setting[/b]:
1K +39 2K +13 3K + 6 4K +3 5K +3 5.5K + 3 6K +3 7K +3
High Setting[/b]:
1K -10 2K -10 3K -10 4K -10 5K -3 5.5K +6 6K +8 7K +8
TH-Point
Lo 30% Hi 80%
2G Turbo
Big 16 G Turbo, Apex Cat Back, RRE[/b] DP-3" Cat, Filter, 19psi, Front Mount I/C, Walbro 255 HP in tank pump,550cc Injectors, honeycombs all in, Adjusting screw left alone, Big GReddy FMIC
Low Setting[/b]:
1K +-2 2K -4 3K -6 4K -10 5K -10 5.5K -10 6K -10 7K -10
High Setting[/b]:
1K -21 2K -23 3K -24 4K -23 5K -22 5.5K -22 6K -21 7K -18
TH-Point
Lo 30% Hi 80%
2G Turbo
Low Setting[/b]:
High Setting[/b]:
TH-Point
Lo 30% Hi 80%
2G Turbo
Low Setting[/b]:
High Setting[/b]:
TH-Point
Lo 30% Hi 80%
ORIGINAL: theinnereffect
ive seen people tune 650's using an afc and a logger so i say its doable
but if you have the wideband just install it
