Tuning w/o wideband
Old Apr 11, 2008 | 02:12 PM
nyc95gst's Avatar
Default Tuning w/o wideband
Ok, I had an SAFC installed on my vehicle. I am running 650 inj. I am not installing my wideband right now, but I need to get my car running. Can I still tune the car fairly well just off the SAFC w/o the wideband. I read in some threads that it is doable. But I wanted to ask what problems I might run into if any.
Thanks
Old Apr 11, 2008 | 02:22 PM
Default RE: Tuning w/o wideband
I wouldnt do it, you could risk your motor. If thats worth it to you then go for it. Id rather take the safe route and do it the right way
Old Apr 11, 2008 | 02:31 PM
yea you really need a wideband otherwise you have no idea what the tune is doing. What are your mods because road race engineering has a couple a decent "startup" tunes for the safc.
Old Apr 11, 2008 | 03:17 PM
nyc95gst's Avatar
650 inj
16G EV III
SAFC
Greddy FMIC
walbro 255
AFPR
ported exhaust manifold
1g bov
apexi n1 3in exhaust
MBC
boost gauge
wideband (not installed)
some other stuff
Dammit man, I really need to get my car running.
Got links to those road race startup tunes.
Old Apr 11, 2008 | 03:43 PM
theinnereffect's Avatar
ive seen people tune 650's using an afc and a logger so i say its doable
but if you have the wideband just install it
Old Apr 11, 2008 | 04:09 PM
why not just install it. It shouldnt take very long, unless your just waiting to have a bung welded or someone. I mean with a pocket logger you could do it as well, but you really need a wideband. But here is a couple of maps from RRE
2G Turbo
16G Turbo, RSR Cat Back, RSR DP-no cat, Filter, 17psi, Front Mount I/C, Denso in tank pump,550cc Injectors, Side and Lower honeycombs out, Adjusting screw backed out flush
Low Setting[/b]:
1K +39 2K +13 3K + 6 4K +3 5K +3 5.5K + 3 6K +3 7K +3
High Setting[/b]:
1K -10 2K -10 3K -10 4K -10 5K -3 5.5K +6 6K +8 7K +8
TH-Point
Lo 30% Hi 80%
2G Turbo
Big 16 G Turbo, Apex Cat Back, RRE[/b] DP-3" Cat, Filter, 19psi, Front Mount I/C, Walbro 255 HP in tank pump,550cc Injectors, honeycombs all in, Adjusting screw left alone, Big GReddy FMIC
Low Setting[/b]:
1K +-2 2K -4 3K -6 4K -10 5K -10 5.5K -10 6K -10 7K -10
High Setting[/b]:
1K -21 2K -23 3K -24 4K -23 5K -22 5.5K -22 6K -21 7K -18
TH-Point
Lo 30% Hi 80%
Old Apr 11, 2008 | 04:10 PM
after looking at that second map that they have, im not so sure i would go that agressive without a wideband because those are someone pretty big Air sensor reductions to be doing.
Old Apr 11, 2008 | 04:44 PM
ORIGINAL: theinnereffect
With a logger Yes, they also prob have one other thing in place. an EGT gauge. In the older Turbo days they only tuned by EGTs so it is possible but no a days AFR is key and why not do it right and not pay for it big timelater
Old Apr 11, 2008 | 04:58 PM
nyc95gst's Avatar
yea yea yea, I'll do it right. Thanks guys
Aaaaarrrrgggghhhhhh!!!!!!!!!!!
burnmyeyes
Jul 7, 2006 11:56 AM
RCJr9186
Apr 26, 2006 05:33 PM
player69x
Feb 10, 2006 09:43 PM
EMonz57
Dec 8, 2005 03:09 PM
EMonz57
Dec 7, 2005 01:52 PM
