Turbo double whistle
Old Oct 31, 2006 | 11:36 AM
burnmyeyes's Avatar
Default Turbo double whistle
I first noticed it when it started getting colder outside. Even my friend, who is a woman, noticed that it sounded different than usual. Basically it sounds like a turbo spooling up, but it sounds like two. I dont think that it is the death whine. I dont know how old the turbo is, but it could very well be on its way out. I forgot but my mechannic reminded me there is also a 2 1/4' universal catalytic converter on my 3' exhaust which probably doesnt help the turbo breathe. I am getting either a high flow cat or test pipe to replace that later this week.
But anyway I was just wondering if the whistle meant that the turbo it was starting to die. Thanks.
Old Oct 31, 2006 | 02:12 PM
Default RE: Turbo double whistle
It might be on its way out to die. Take the intake off and see if you can make the compressor touch the housing. Just wiggle it.
Old Oct 31, 2006 | 03:17 PM
burnmyeyes's Avatar
yeah thats what Im thinking. its just not pulling like it used to.
I'll check it out when I get out of work.
Old Oct 31, 2006 | 03:34 PM
The wheel will touch the housing I think that it is normal to have shaft play in that direction BUT ONLY MINIMAL I think it is in and out it shouldnt move.
Old Oct 31, 2006 | 04:49 PM
burnmyeyes's Avatar
Okay so in simple terms, the shaft may touch the housing, but any play in the shaft itself means the turbo is garbage, correct?
Old Oct 31, 2006 | 05:23 PM
basically hold the shaft, wiggle it up and down and side to side, if its moving alot then its bad, then try and push it in and out, if it can do that then its really bad
Old Oct 31, 2006 | 05:39 PM
burnmyeyes's Avatar
thanks
tcp
Aug 6, 2010 09:14 AM
casr
Jul 15, 2010 06:43 AM
Simss
21
Oct 6, 2006 12:34 AM
imtalkintou
Mar 22, 2006 01:45 PM
trek
Nov 15, 2004 03:52 PM
