Upgrading fuel - does this make sense?
I found this at: https://mitsubishiforum.com/m_78380/tm.htm
HKS Vein Pressure Converter (VPC)
The VPC is a fuel computer system that replaces the factory Mass Airflow Sensor (MAS) setup with a Manifold Absolute Pressure (MAP) assembly and controller. The benefit of this conversion is that the flow of the intake system is improved by eliminating the restrictive factory MAS sensor assembly.
This modification allows the blow-off valve to be vented to the atmosphere for better performance and sound, as well as allows the use of a much larger, better flowing air filter assembly and larger injectors (if using larger injectors, request the custom Buschur Racing PROM for larger than stock injectors).
taken straight from buschur's website.
Just wondering.
Just wondering.
swnkylaxplyr
Sep 9, 2008 04:41 PM
