Does this make any sense? *timing belt question*
Old Sep 8, 2008 | 12:00 PM
swnkylaxplyr's Avatar
Default Does this make any sense? *timing belt question*
A week ago I replaced the valve cover gasket and I noticed that the timing belt had a ton of play in it, despite the fact that it was replaced about 15k ago. I got everything back together, and just checked the belt again today and its nice and perfectly tight. Does this make sense?
Old Sep 8, 2008 | 03:26 PM
jerusry's Avatar
Default RE: Does this make any sense? *timing belt question*
that is just how it goes... mine have been the same way. if it sits for a little while the belt is loose... or loose(er) than when i have just run it for a second. it will be tighter after you start it up.
Old Sep 8, 2008 | 03:45 PM
dsm1990gsx's Avatar
Yeah mine does that too as long as you used an oem belt and tensioner you'll be fine.
Old Sep 9, 2008 | 04:41 PM
Manybrews's Avatar
you have a hydraulic tensioner.
if the system is shut off with a load placed on it, it will slowly compress. As soon as the car is started, the load shifts and the tensioner extends.
dont worry about it.
myoung2746
Jan 12, 2014 12:31 AM
rustyc
May 8, 2010 02:00 PM
nyc95gst
Mar 22, 2008 04:54 PM
jpmontero98
Dec 3, 2007 01:28 AM
xLoveMeXoTenderX
Jul 28, 2007 11:38 PM
