vibration
Old Sep 26, 2007 | 08:59 AM
98gstspy's Avatar
Default vibration
when i hit the gas petal it seams like there is more engine vibration then ever before im no to sure what would cause this. i resently changed the oil and it happend about 3 days after not really sure if that helps. dose any body know what could be causing this. im probly just making a big deal out of nothing but i still want to know why it is like this
Old Sep 26, 2007 | 09:26 AM
sk8dudety's Avatar
Default RE: vibration
check your engine mounts, maybe one is broken?
Old Sep 26, 2007 | 10:36 AM
does it only have a vibration at low rpms
Old Sep 26, 2007 | 11:00 AM
ComposeEvo's Avatar
Sounds like your idle is too low. Try picking it up.
It could also be your timing is too retarded. Check both. Or as sk8 said, your mounts just gave out competly.
Gus
Old Sep 27, 2007 | 09:07 AM
98gstspy's Avatar
my idle isnt low it is actually running like it should for once, it happens when i hit the gas it isnt to bad but i notice it and i can normally tell when something is wrong with the car. i took a look at the upper engine mounts they look good. havent had any time to look at the lower ones but i am hoping that is what the problem is because i dont have the money for the timing belt right now.
Old Sep 27, 2007 | 09:43 AM
RCJr9186's Avatar
ignition. check ur plugs. how long has it been since it's had a tune up? i'd personally replace the plugs, wires and coil pack. i had the same or a similar problem in my car when i first got it, replaced these 3 things and it ran like a champ.i replaced my spark plugs like 3 times and it would run good for about a day or 2 then do the same thing. pull the plug wires off the coil and see how the prongs look. mine were rusted and coroded.
Old Sep 27, 2007 | 11:00 AM
sk8dudety's Avatar
welltheysaid it was vibrating, not missing or bogging down when they hit the gas. If it were bad plugs and wires etc then it would be bogging down and they wouldnt be getting the power they should. But it's just vibrating and since the idle isnt low i'm willing to bet its the mounts
Old Sep 27, 2007 | 02:46 PM
Plugs and wires is my best guess : )
00GalantMan
Jan 29, 2006 01:08 PM
wulls1313
Aug 21, 2005 12:54 PM
95EclipGS
Aug 9, 2005 09:24 PM
2step
Feb 8, 2005 09:57 PM
Davet2
Oct 18, 2004 01:39 PM
