water leak 99 eclipse gs
Old Oct 19, 2007 | 03:15 PM
sk8dudety's Avatar
Default RE: water leak 99 eclipse gs
have someone sit in the car while you run a hose over your hatch area, then you'll be able to see exactly where's its leaking from
Old Oct 19, 2007 | 07:01 PM
chopper1's Avatar
Make sure the drainson the sides of the hatch where the lift struts attach are clean. If they are pluged water will pool up next to the hatch weather stipping and follow the easiest path down.....Cleaned mine with a piece of #16 wire.
Old Oct 19, 2007 | 08:53 PM
98eclpsrider's Avatar
i had that, and i just drilled two holes in the plug under the spare and i don't have that anymore.
Old Jul 5, 2014 | 05:27 PM
gsx1998loveit's Avatar
Default water in tire well
My 1998 GSX was rear-ended, and ever since it was repaired water collects in the spare tire well whenever I drive through a puddle, no matter how fast or slow. It never happens just from rain (I park it outside). The drain tubes are fine, and all the seals look good. Apparently it is coming in from somewhere below. The dealer hasn't been able to find anything wrong, and it's the best car dealer I've ever worked with, so no complaints there. And the water does something to the wiring back there that sometimes sets of my security alarm. Any ideas?
JohnnyK
Jun 2, 2011 01:10 PM
TheRock0720
Nov 12, 2010 12:30 PM
CJ3B
Oct 8, 2010 05:21 PM
pratzert
13
Aug 10, 2010 02:41 PM
mysterio2099
Feb 27, 2006 02:27 PM
