Water pump
Old May 29, 2008 | 08:10 AM
ridingDSM0201's Avatar
Default Water pump
I have a 95 rs how much of a pain would it be to change the water pump? anyone with step by step procedures? or pretty close to step by step i wanna make sure i get this right the first time.
Old May 29, 2008 | 02:57 PM
Default RE: Water pump
if you can change out a timing belt, then you can do the water pump. There is only a few more steps after removing the timing belt and all the parts before taking the water pump out. So if you feel comfortable with a timing belt then go for it
Old May 29, 2008 | 03:06 PM
yea i was thinking about that..... never did it before. but i figure if i dont turn the crank or the cams will i mess up the timing? i mean any pointers on getting the belt back on like should i put the teeth for the cam gears on first and move to the left or right or what??
Old May 29, 2008 | 04:20 PM
you have to remove the timing belt in order to do the removal. The bestadvice i can tell ya is to go and buy a haynes manual. They are only like $20 and will have all the steps to doing it correctly
Old May 29, 2008 | 05:00 PM
ok sounds good. thanks guys
JohnnyK
Jun 2, 2011 01:10 PM
bcolins
Jul 5, 2007 07:35 PM
g9s5t
Aug 21, 2005 10:01 PM
*master
Mar 4, 2005 11:33 PM
Knaackers
Jan 14, 2005 02:54 AM
