Weird BOV noise? is it normal for a 1g?
Old Aug 7, 2007 | 01:31 PM
dorian7's Avatar
Default Weird BOV noise? is it normal for a 1g?
So I installed my new UICP and 1g bov yesterday, but it is weird whenever the engine in just slightly reved it makes a weird squeeking noise (very similar to swueeky breaks) is that normal? it is almost like a whistle. Do i need to oil the bov or somthing?
Old Aug 7, 2007 | 01:47 PM
jlh077464's Avatar
Default RE: Weird BOV noise? is it normal for a 1g?
Whistle?, Maybe a boost leak?
Old Aug 7, 2007 | 02:00 PM
RCJr9186's Avatar
good call, sounds like boost leak to myself also... not that i'm insulting youor anything but it's not a loose belt is it? (always gotta check the most common sense things first lol) if not, i'd build/use/buy a boost leak tester. check all your cupplers and have a friend rev it to where it's squeeling and see if you can pinpoint it.
Old Aug 7, 2007 | 02:38 PM
that is a normal sound. If it is almost a humming noise, yes that is perfectly normal for the 1g BOV's to do that. I had one and my 2g and used to have fun trying to see how long i can keep the noise going
Old Aug 7, 2007 | 11:50 PM
anko_kun's Avatar
my 1gen does the same thing it is fine just like TheEngineersaid
Old Aug 8, 2007 | 12:29 AM
racerx55's Avatar
i always hear it out of mine, on a free rev when the engine has vaccum the BOV will open and let some air out and something with the design of them makes it whistle a little.
Old Aug 8, 2007 | 04:18 AM
dorian7's Avatar
Huh yeah it is so weird, it sounds kind of like squeeky breaks. When I installed the BOV I didnt use any gasket sealer, is that necessary?
Old Aug 8, 2007 | 04:53 AM
racerx55's Avatar
as long as you put a gasket on it you should be fine.
you might want to check for boost leaks just to be safe. any leaking gaskets will squeal or buzz somtimes.
ShortyRider
Dec 13, 2012 11:52 PM
lhausi2
Jan 16, 2008 07:51 PM
piotrekmile
Sep 21, 2006 07:18 PM
agallardo
May 24, 2006 10:34 PM
kb0282
May 2, 2005 08:07 PM
