what kind of motor do i have
Old Nov 5, 2005 | 09:22 PM
Default RE: what kind of motor do i have
ORIGINAL: Patrick
im guessing that it was a base base model?
I guess so it must be a somewhat rare motor because I havent seen it much.
Old Nov 5, 2005 | 10:21 PM
Sanguinius's Avatar
Does it say DOHC on the valve cover? That's definately the 4G63 then...
Old Nov 6, 2005 | 01:48 AM
slow420a's Avatar
Motor trims for 1g's
eclipse's
gsx/gst 4g63-t 2.0 doch
gs N/T 4g63 2.0 doch
eclipse <in 1g's their werent rs's, just "eclipse"> 4g37 1.8 soch
Talon's
tsi, tsi awd 4g63-t 2.0 dohc
esi n/t 4g63 2.0 dohc
DL 4g37 1.8 sohc
Old Nov 6, 2005 | 12:42 PM
Patrick's Avatar
Administrator
did the NA 4g63s have different pistons, or a different head, or both?
Old Nov 6, 2005 | 02:06 PM
get435's Avatar
ORIGINAL: slow420a
eclipse's
Talon's
DL 4g37 1.8 sohc
just a small correction
gsx/gst 4g63-t 2.0 dohc
gs N/T 4g63 2.0 dohc
eclipse <in 1g's their werent rs's, just "eclipse"> 4g37 1.8 sohc
Old Nov 6, 2005 | 03:43 PM
92_laser's Avatar
ORIGINAL: Patrick
I am almost positive that the non turbo 4g engine has the same internals/head and everything. Just no turbo.... wiring/ecu is different
Old Nov 6, 2005 | 04:14 PM
Sanguinius's Avatar
NA 4G63's have different valves but the same heads from what I've found in my research and I believe the pistons and teh rods are a bit different too. When I get my NA up here I have a set of T pistons and rods sitting here so I'll compare them and let you guys know for sure.
And the 1G's had the GS not just Eclipse (I can give you my VIN for my '92 it comes up in carfax as a GS).
Old Nov 6, 2005 | 06:07 PM
slow420a's Avatar
ORIGINAL: get435
ORIGINAL: slow420a
eclipse's
Talon's
DL 4g37 1.8 sohc
what you never herd of a double over cam head motor... i guess you didnt watch F&f enough like i did
Old Nov 6, 2005 | 06:24 PM
[/quote]
[/quote]
the head is different in the 4G and 3G compared to the 1G\2G 4G63 but they do share the same pistons and rods as the 2Gs 4G63 from what I have read.
Old Nov 6, 2005 | 07:37 PM
Sanguinius's Avatar
Yeah I'm sure the head should be the same it's the valves that are different if I'm not mistaken. The NA valves are smaller I believe.
