What you think starting problems...
Old Oct 21, 2007 | 09:56 PM
AzAuto's Avatar
Default What you think starting problems...
The car starts fine if you jump the car from the battery to the starter but by turning the key and pressing clutch I get nothing. its a 95 GSX, It has a new starter,new battery, and new cables. I think it is either clutch start switch or starter relay. I can check the clutch start switch by just unplugging it but what about the starter relay where is it on this car.
Old Oct 21, 2007 | 10:17 PM
nick_200321's Avatar
Default RE: What you think starting problems...
im thinking the clutch start switch. if you can start it by jumping battery to starter it shouldnt be the starter relay
Old Oct 22, 2007 | 06:37 AM
Seriously how can you people think its has anything to do with the starter. If it was the relay then dont you think the car wouldnt start when its getting jumped either . Id say jump the car, and then check the voltage at the battery with a tester. You should be getting 14 volts. If its less then you have a bad alternator. Also check the terminals on the battery, they may be corroded. Just replace those
Old Oct 22, 2007 | 09:19 AM
TheAdvocate's Avatar
With mine, the connection on the back side of the starter doesnt seem to get a good conection and I have to pop it off and put it back on.. If it doesnt have a good connection it wont be getting enough power to start it..
Old Oct 22, 2007 | 10:55 AM
atown420's Avatar
when i was swapping out my old blown engine we could start it like you are but when i tried to use the key it wouldnt do anything there was a little plug that wasnt plugged in on the back side of the motor and as soon as i plugged it in bam it turned on. so i dont know if that could be it im just giving you another option. but if you werent swapping motors i dont know how that would come off or unplugged hope this helps
Old Oct 22, 2007 | 11:45 AM
Actually TE, when the starter on my moms GST was sticking, the added power would sometimes free it.
Old Oct 22, 2007 | 05:18 PM
but i was also thinking as i was replying that it could possibly be the alternator.. but i wanted to see if what he thought it was was right first
Old Oct 22, 2007 | 08:57 PM
AzAuto's Avatar
Thanks for all of your help!!
Edited for lack of respect.
Old Oct 22, 2007 | 10:31 PM
that was unneeded, all we were doing was trying to help you solve your problems, if you were that damn positive why did you even ask.. no need for an attitude here, geez
jp2000
Jan 1, 2012 05:21 PM
gsr94trycatchit
Jan 17, 2005 03:10 PM
Nathan
Dec 3, 2004 01:13 PM
FatalJRA
Nov 3, 2004 08:02 PM
GalantVR4
Aug 18, 2004 01:13 AM
