What's common for Turn signal, brake, battery lights?
Old Aug 15, 2006 | 07:34 PM
ricketter's Avatar
Default What's common for Turn signal, brake, battery lights?
Started car today after short trip, the dash brake light and battery light stay on and the turn signals and emer flashers do not work.
Brake fluid is fine, emergency brake was not set. Voltage at the battery is 14+ v when running, 12+ when off. All other lights, headlights, running lights, and brake lights are fine. There does not seem to be a fuse for turn signals, and only a 10amp(which is good) listed for emer flashers.
Any ideas?
Thanks
rick
Old Aug 15, 2006 | 07:51 PM
Nubiebubie_GSX's Avatar
Default RE: What's common for Turn signal, brake, battery lights?
Well for me when i got water splash on my alternator my brake light and battery light came on and off. Maybe u need a new alternator. Just a suggestion to check.
Old Aug 16, 2006 | 02:03 PM
ricketter's Avatar
ORIGINAL: Nubiebubie_GSX
Well, I don't think it is. that was why I mentioned the volts from the alt being solid at 14+ volts. I'm thinking I need to look more at a link/switch/module that some bit of power goes through and has outputs for these items. Looks like this year eclipse doesn't have a flasher unit, but the manual I have isn't very specific in the wiring area.
Old Aug 16, 2006 | 03:11 PM
RCJr9186's Avatar
take it to an auto part store and have em run a free diagnostic. they may be able to tell you why they are on and lead you to the problem
Old Aug 16, 2006 | 04:44 PM
ricketter's Avatar
ORIGINAL: RCJr9186
I might give it a try, but it's not showing any codes on the hand-held reader i have and the check light isn't on. Is it possible to have codes and not have the check light on?
Old Aug 16, 2006 | 08:02 PM
slvr_eclipse's Avatar
yea I believe so. There can be codes that are on there until you have them erased even after the problem has been fixed. There are two different kind and i cant remember what they call them.
Old Aug 17, 2006 | 03:21 PM
ricketter's Avatar
Problem solved...
Actually there was a fuse somewhere under the hood. Wasn't listed as turn signal.
Don't know which one directly, the guy that replaced it wasn't there when I picked the car up.
I guess next time I won't depend on labels and diagrams.
foutong
Dec 4, 2007 05:44 AM
gotzenjoi
Dec 2, 2007 01:26 AM
gotzenjoi
Dec 1, 2007 11:53 PM
capecodder
Aug 4, 2007 08:32 PM
dornstar
May 22, 2006 04:58 PM
