Is this where the O2 sensor wire should be?
There is a tube under the car which I'm assuming is either a drain tube for the sunroof or where the rear O2 sensor wire is supposed to come from. Any input before I pull the seat out to find whats there??????
By the way. Youthink it's scraped a few times???? Too low to get that front lip.
[IMG]local://upfiles/13708/5011F150157743528275FC0E010C8092.jpg[/IMG]
RE: Is this where the O2 sensor wire should be?
yea that wire feeds up to just under your driver side seat... looks like someone put a bolt in the o2 bung, you can get a o2 sensor from advance or autozone and it comes with that wire attached. Just pull out that bolt in the bung, screw in the 02 sensor, and feed it up through that spot in the floor, easy fix
