Is this where the O2 sensor wire should be?
Old Oct 3, 2007 | 03:43 AM
chopper1's Avatar
Default Is this where the O2 sensor wire should be?
There is a tube under the car which I'm assuming is either a drain tube for the sunroof or where the rear O2 sensor wire is supposed to come from. Any input before I pull the seat out to find whats there??????
By the way. Youthink it's scraped a few times???? Too low to get that front lip.
[IMG]local://upfiles/13708/5011F150157743528275FC0E010C8092.jpg[/IMG]
Old Oct 3, 2007 | 06:12 AM
Default RE: Is this where the O2 sensor wire should be?
that looks like an O2 hole and it appears the bung for the 02 is closed. Thats is right after the cat correct?
Old Oct 3, 2007 | 08:30 AM
sk8dudety's Avatar
yea that wire feeds up to just under your driver side seat... looks like someone put a bolt in the o2 bung, you can get a o2 sensor from advance or autozone and it comes with that wire attached. Just pull out that bolt in the bung, screw in the 02 sensor, and feed it up through that spot in the floor, easy fix
jthorn75
May 23, 2012 02:40 PM
eugenexyu
Aug 30, 2010 07:52 AM
Teejay36
Sep 11, 2007 08:10 PM
imtalkintou
Mar 17, 2006 06:17 PM
faded2
Jan 19, 2006 08:43 AM
