will a FMIC help?
I cut the plastic stuff that was behind my SMIC off and it seems like i have more power.
I was thinking about putting in a FMIC because it seems like having my incomming air just a little cooler helps.
yes i have the stock turbo but i really think it would help. OPINIONS PLZ?
For those that are lazy skip to the end...
well if you want to get a fmic then get one, your taking ambient air and cooling it before it enters the motor so yes it will make a difference. In your case I dont think its going to make all that much of a difference not because of the stock turbo but because your running the stock psi level. Your smic is matched up to give you cool enough charge but when you increase the boost levels the stock tends to get heat soaked failry fast. I would recomend slow boy racings fmic, its cheap, fits nice, and does the job. If I am not mistaken it goes for something like 850.
Nut shell: yes it helps, even better if you want to do more upgrades.
t3t4turbo
02-20-2005 03:25 AM
