will a FMIC help?
Old Aug 6, 2006 | 11:08 PM
paintballproam's Avatar
Default will a FMIC help?
I cut the plastic stuff that was behind my SMIC off and it seems like i have more power.
I was thinking about putting in a FMIC because it seems like having my incomming air just a little cooler helps.
yes i have the stock turbo but i really think it would help. OPINIONS PLZ?
Old Aug 6, 2006 | 11:34 PM
davidmitsusrock's Avatar
Default RE: will a FMIC help?
i think it will help a bit pluss fmic's just look soo good!
Old Aug 6, 2006 | 11:43 PM
yea thats what i was thinking, plus it will do alot more than my smic. Would it fit with my stock bumper? 95 tsi awd?
Old Aug 6, 2006 | 11:56 PM
doubtful may have to do some cutting depending on how big it is
Old Aug 7, 2006 | 12:02 AM
5Tizzle's Avatar
cutting will be necessary. and if youre just gonna run your stock turbo, dont go too big on the intercooler, or piping, or else youll lose some power
Old Aug 7, 2006 | 12:35 AM
slow420a's Avatar
For those that are lazy skip to the end...
well if you want to get a fmic then get one, your taking ambient air and cooling it before it enters the motor so yes it will make a difference. In your case I dont think its going to make all that much of a difference not because of the stock turbo but because your running the stock psi level. Your smic is matched up to give you cool enough charge but when you increase the boost levels the stock tends to get heat soaked failry fast. I would recomend slow boy racings fmic, its cheap, fits nice, and does the job. If I am not mistaken it goes for something like 850.
Nut shell: yes it helps, even better if you want to do more upgrades.
Old Aug 7, 2006 | 09:23 PM
Totally agree with Slow. Its worth it but i would get the FMIC with a 16g turbo or something. Running it at 15psi youl love it
Old Aug 21, 2006 | 06:36 AM
romanrapido's Avatar
does that mean FMIC will not work on stock turbo? will lose torque? did i get that right?
PoolhallJunkie777
Jun 7, 2008 11:55 AM
BrunoBoy650
Apr 8, 2006 05:51 PM
get435
Dec 18, 2005 09:55 AM
DSMDUDE
Mar 30, 2005 09:59 PM
t3t4turbo
Feb 20, 2005 03:25 AM
