wont run
Old Mar 14, 2006 | 08:29 AM
tidus10's Avatar
Default wont run
ok i got my eclipse spyder gs with my ram air intake...(4").. and now i start it and it idles soo low it stalls....what could be my problem.. my dad says the battery being dead could do it.. but i'm now a 100% sure about that.. any feedback would be great...
Old Mar 14, 2006 | 10:38 AM
My93EclipseGS's Avatar
Default RE: wont run
Do you still have the MAF hooked up with the Ram Air Intake?
Old Mar 14, 2006 | 10:58 AM
slow420a's Avatar
Ya, 4" is a lil too much for a intake on a n/a car, mine was only 2.5 and it worked fine, I would say you have a leek some where behind the maf thats making the motor lean out.
Old Mar 14, 2006 | 01:42 PM
just check all the connections in the piping and check maf, hopefully you didn't damage it at all. also make sure that all the wires are reconnected to the maf
Old Mar 14, 2006 | 04:43 PM
Sanguinius's Avatar
Also check for corrosion that could be causing a connectivity problem with the connector.
Old Mar 14, 2006 | 09:54 PM
tidus10's Avatar
one of my friends said it may be a vacuum line problem.... i hope i didnt damage anything.. all the fittings are secure...
LUKESGARAGE
Nov 16, 2013 03:34 PM
brknhrtdpimp1489
Mar 26, 2007 02:27 AM
ktown
May 29, 2006 10:47 PM
dsfii
May 10, 2005 03:08 PM
Puppet0
Dec 28, 2003 01:30 PM
