Won't shift help
Old Jan 4, 2007 | 05:27 PM
rx74dd1ct's Avatar
Default Won't shift help
Hello,
I just bought a 1998 GS from an auction, this is my first Eclipse, anyway the problem is that it won't shift, this is an automatic, it only runs on 1st, also the speedometer doesn't work I don't know if that has anything to do with the shifting problem..., anyway any tips on where or what to check ????
Thx
Andy
Old Jan 4, 2007 | 06:06 PM
paintballproam's Avatar
Default RE: Won't shift help
does it get to redline? its probably your TCM
Old Jan 5, 2007 | 08:08 AM
silvercoupe97's Avatar
Sounds like limp mode. Do the normal checks...fluid, fuses, relays, CPS. If all checks well, then take it to a garage.
Or you can just start changing things, the TCU, like what Paintball suggested, CPS, firewall relays, fluid and filter (that has a major influence on any auto tranny btw), clutch solenoid (yikes), tranny (bigger yikes).
Old Jan 5, 2007 | 08:22 AM
happend on my 91, it was the tcm. I changed it and it was fine
Old Jan 5, 2007 | 08:39 AM
racerx55's Avatar
Rule #1 ive learned as being a mechanic with that problem, replace the VSS (vehicle speed sensor). First just make sure its plugged in.
its the cheapest quickest fix, if that doesnt fix it, return the part and say you didnt need it. Then go for a TCM.
When you get it straight be sure to let us know what the problem was.
Eclipse440
Jul 14, 2015 11:08 PM
Ms.Fixit
Sep 12, 2010 01:43 PM
fordsrule
Aug 15, 2010 12:01 PM
demii
Sep 1, 2008 10:18 PM
Jdg784
Jan 22, 2006 05:01 PM
