WTB: 97 RS 2.0 stock air intake.
Old Oct 18, 2004 | 08:41 PM
shamsulaswad's Avatar
Default WTB: 97 RS 2.0 stock air intake.
hello there,
i'm looking for a stock air intake kit that includes everything from the pipe to its air filter box. reply or email me back if you have one for sale. winter is coming in Indiana and i can't be using cold air intake through out it. please let me know. Thanks
Shamsul
P/S: sorry to post it hear since this is the only section that have many viewers.
Old Oct 19, 2004 | 02:54 AM
FatalJRA's Avatar
Default RE: WTB: 97 RS 2.0 stock air intake.
I'm not sure if cold air could stall your engine. What kind of cold air-intake are you using? If you are worried about getting your intake wet, I would use AEM's bypass valve. Also INJEN makes a metal frame that goes around the cone to protect it from water. Or the best thing to do is to get a short ram intake. That way the intake will not be circulated cold air into your engine, but a little bit of cold and warm.
Otherwise, buying a stock intake will cost you a bit. I'd try ebay before the dealer.
Old Oct 19, 2004 | 08:24 AM
well, i bought the car from a guy in texas. he customly made the intake. it includes 2 fans to suck in the air from outside. its like any normal intake with the filter but with 2 fans in the middle. how does the installation goes for the short ram intake? will it fit my engine? Thanks
Shamsul
Old Oct 19, 2004 | 07:41 PM
FatalJRA's Avatar
Yeah, short ram intakes will fit your car. I have a 98 spyder eclipse which is a 2.4 engine and they don't make intakes for my car. I had to make a custom intake. But for the RS 2.0, AEM and INJEN are probably the best. It's basically a short elbow intake that doesn't extend all the way down into your engine so you are getting a little bit of warm and cold air. I've seen intakes such as the one you are describing to me. I'm not sure if the fan really makes that much of a difference. Check out Streetstyler.com, matrixracing.com, sounddomain.com for intakes. Sometimes you can find stuff cheaper on ebay. I would also call one of these websites to see if a short ram would be ok to use in the cold weather.
Old Oct 19, 2004 | 08:01 PM
1398spdr's Avatar
i personally kept everything stock, except the snorkle, i cut it off and stuck the cone intake filter on the end and took out the stock air filter, works almost exactly the same, maybe a little better cause it seems like you have a resivoir of air to pull from when you hit the gas.............
Old Oct 19, 2004 | 09:51 PM
i went to sounddomain.com and found that they sell cold air intake system and air intake system. what are the differences?
Old Oct 19, 2004 | 10:22 PM
1398spdr's Avatar
cold air intake is longer, it pulls air from down by the ground and a normal intake pulls air from the engine compartment, the air in the engine compartment is a lot warmer, thats why its a cold air intake cause the air by the ground is colder, they also tend to work a little better, give ya 1 or 2 more hp............
Old Oct 20, 2004 | 01:05 AM
FatalJRA's Avatar
The air intake is the short ram intake that I was describing to you. I'd go with that over the cold air in your situation. Also if you drive in really wet areas and don't want your cone filter to get wet, I'd stay away from the cold air intake, just stick with the short ram/air intake. And I believe the short ram will run you around $95-130 depending on the website. Sometimes just typing in AEM or INJEN on yahoo will bring up companies that sell these products at wholesale prices.
Old Oct 20, 2004 | 02:08 AM
well, i found some AEM short ram intake listed on ebay for les then 100 bucks shipped. do you think it is the original from aem?
Old Oct 20, 2004 | 01:06 PM
SpyderGS's Avatar
Personally, i had the injen intake on my old 97 talon and i didn't feel any difference. I "heard" a difference, but couldn't feel anything. You're probably better off with the stock system since it gives a better level of protection. Look on DSMtrader.com for the stock system, i'm sure someone's trying to sell it.
Also, FatalJRA the Integra GSR Intakes fit the 2g Spyder GS's. Kinda weird, but it works. This was discovered about 2 years ago by members of TGC, so i have to give credit to them.
