00 eclipse gt misfiring in low rpms CODE P0300
Old Aug 18, 2013 | 02:15 PM
WackJobRacing27's Avatar
Default 00 eclipse gt misfiring in low rpms CODE P0300
I been having problems in my 00 eclipse gt in low rpms. It spits an putters in low rpms. Ive had the distributer and router replaced. Cleaned fuel injecters. EGR valve is good. Put new plugs and wires in. im thinking that the timing jumped or the crank sensor went. Any help from u guys is much appreciated . I have alot of after markets in this car and I would hate for a problem like this cause a serious problem.
Old Aug 18, 2013 | 02:17 PM
One thread will do.
Old Aug 19, 2013 | 06:47 AM
Jeff Collision's Avatar
The P0300 code means that a cylinder(s) is misfiring or is randomly misfiring. Start by checking for intake leaks, intake gaskets are common caused of multi-cylinder misfiring. If no leak are found the next step is to replace the plugs. If the problem persist more tests needs to be done to diagnose problem, the possible causes are Faulty ignition coil, Clogged or faulty fuel injector, Intake air leak, Fuel injectors harness is open or shorted, Fuel Injectors circuit poor electrical connection, Ignition harness is open or shorted, Ignition circuit poor electrical connection, Insufficient cylinders compression or Incorrect fuel pressure.
Old Dec 28, 2020 | 09:15 PM
Stan Ashford's Avatar
How do you check ignition module I'm not getting any spark on three and six coil pack
WackJobRacing27
Aug 18, 2013 02:14 PM
Buzzer_k
Jul 22, 2013 01:00 AM
Navydude246
Jul 29, 2011 07:23 PM
neurocrash
Apr 20, 2008 08:04 PM
ajav05
Oct 1, 2006 02:32 PM
