Loud tapping, low compression in no. 6, misfiring
Old Jul 2, 2013 | 08:36 PM
Buzzer_k's Avatar
Default Loud tapping, low compression in no. 6, misfiring
I replaced my valve stem seals, replaced all the lash adjusters with new ones, bled then with diesel fuel as the manual states, and it still misfires, runs rough, stalls when I stop, and the tapping - we'll, I'm afraid I've bent a valve. I did replace wires, plugs, timing belt, water pump, etc. I also cleaned the throttle body and plenum. They were coated with a black, gritty substance, that was wet, not dry. That was before I got into it. Any expert advice will be greatly appreciated.
Old Jul 3, 2013 | 06:15 PM
Buzzer_k's Avatar
Oh, It's a 2001 Montero Sport with a 3.0 engine
Old Jul 14, 2013 | 08:59 AM
Buzzer_k's Avatar
Update: I pulled the heads, and had them vacuum tested. The valves need cleaning and lapping, but the engine guy who tested the valves said it's probably a stuck ring.
Old Jul 14, 2013 | 10:25 AM
mxmikie's Avatar
i have never heard a Loud tapping with a stuck ring....................
Old Jul 15, 2013 | 09:26 PM
Buzzer_k's Avatar
Something either fell into the cylinder or part of the plug broke off and banged up the piston and the cylinder. I had all the openings covered with rags, but something must have fallen in. I found something about the size of two BB's in there. The engine guy said I probably have a pinched ring from debris. He recommends I replace the no. 6 piston, all the rings, and the rod bearings. I don't think I can get to the main and thrust bearings with the block still in the truck. My concern is I'll have new rod bearings and 300k on the main and thrust. I'm thinking I should just pull the block and rebuild the lower end too while I've got the heads off.
Old Jul 22, 2013 | 01:00 AM
Akzle's Avatar
haul the engine out and rebuild it.
better to do it once, top to bottom, than have to do the top now and the bottom later.
WackJobRacing27
Dec 28, 2020 09:15 PM
WackJobRacing27
Aug 18, 2013 02:14 PM
neurocrash
Apr 20, 2008 08:04 PM
paintballproam
Jul 14, 2006 06:10 PM
iceman
Feb 4, 2006 12:00 AM
