03 spyder eclipse- mystery drain on the battery help
Old Jun 27, 2013 | 04:36 PM
fairiegirl83's Avatar
Default 03 spyder eclipse- mystery drain on the battery help
OK I have a 2003 2.4l eclipse spyder convertible that has a mystery drain. I bought a new battery and the following morning it was drained. Looking around the forum I went and bought a test light so I could find the circuit that the mystery drain is on.
Well that idea failed as it popped the light on 2 test lights the moment I touched the probe to the battery post. I'm figuring that whatever is doing the draw is pulling a lot of power but now I'm not sure how to find it. Any ideas to point me in the right direction.
Also to Note: The a/c compressor locked up and broke a belt so it was replaced last week by a mechanic. Now when I got the car back there was a wire tied into the a/c wiring that runs around the engine to the fuse box and is wrapped around a 20amp fuse (the fuse cover has a picture of an engine on it for that fuse) The mechanic said that it jumps power to the a/c and that it is not causing the drain.
Also when I did check the fuses the a/c fuse (under hood) was bad and I replaced it.
Please help, thank you Mel
Old Jun 28, 2013 | 06:00 AM
Akzle's Avatar
sounds like a short. Disconnect the new wiring and try again.
Old Jun 29, 2013 | 01:06 PM
I did disconnect the wire and no more drain, now I just need to reconnect the wire that the mechanic cut. Remember to check fuses if u replace something & it still doesn't work. As that was the reason he ran a wire to the fuse box. Thanks though for the help
Old Jun 30, 2013 | 12:22 PM
Akzle's Avatar
so, problem fixed?
Josh0301
Aug 16, 2015 01:43 PM
Eclipse440
May 17, 2012 10:23 PM
katauska
Jan 5, 2009 01:12 PM
tjbiker031
Sep 12, 2007 11:06 AM
Grammyami
Mar 12, 2006 04:00 PM
