Battery drain linked to fuses 22&23 2003 GT
Old Dec 3, 2008 | 12:46 PM
katauska's Avatar
Default Battery drain linked to fuses 22&23 2003 GT
Hello everyone. I have a 2003 Eclipse GT, and recently have been having problems with the battery draining down. I have had to jump start the carevery morning for the past 2 weeks, and again after work each day. I just replaced the battery about 2 months ago, and I have checked the battery voltage and the alternator and both seem to be fine. The problem I found was that the battery was drawing about 120 mA current with the key out of the ignition. I started pulling fuses in the engine compartment and found that when I pulled fuses 22&23 (which for some reason are together in a yellow plastic holder), the current draw dropped to about 1 mA. It seems to me that this excessive current draw is what has been draining my battery, and when I pulled the fuses overnight, the car started right up this morning. Fuses 22 & 23 are (according to the manual) for the Dome Light and Audio. I also found that when I pull these, the power door locks do not work as well. Does anyone have a suggestion as to how to find the problem now that I have narrowed it down to these circuits? And is there a reason they are in the plastic holder that I can't take out? I don't think the fuses are blown, as the radio and dome lights work fine if I push the fuses back into place. Please help, I don't want to drive with all these features disabled forever.
Also, I took the car to the local Mitsubishidealer yesterday (before I found the source of the drain), and they told me that it was a battery problem. The battery holdsvoltage fine when it is not being drained, so I know that is not the case. Thanks in advance for any help.
Old Dec 21, 2008 | 02:28 PM
Dusty Eclipse's Avatar
Default RE: Battery drain linked to fuses 22&23 2003 GT
Sounds like miswiring of an aftermarket stereo, and/or a loose/insufficient ground somewhere, pull the head unit out and check the wires.
Old Jan 5, 2009 | 01:12 PM
katauska's Avatar
It is a factory-installed radio, I have not put in an after-market part. I will try to pull it out and check for a loose wire. Anyone else have any other suggestions?
Sébastien Lafeuille
Jun 4, 2014 01:54 PM
steven.searston
Nov 16, 2011 12:20 PM
Solariel
Oct 6, 2010 10:11 AM
jimbowe
Mar 16, 2006 07:35 AM
Grammyami
Mar 12, 2006 04:00 PM
