2000 Eclipse, car vibrates when stopped in drive.
Old Feb 5, 2014 | 12:13 AM
larson6246's Avatar
Default 2000 Eclipse, car vibrates when stopped in drive.
Hi all, I have a 2000 Eclipse that I recently purchased and have done a lot of work to already. My biggest problem now is when at a stoplight and in drive the car vibrates. It is a 2.4 cyl auto, 127,xxx miles. I did have a misfire in cylinder 4, bad coil, replaced, new plugs and wires also. When I accelerate the vibration goes away, it also goes away if I shift to neutral. It is idling 800-900 rpm when problem occurs. Not sure where to start. If I'm leaving out anything that may help pinpoint let me know I'll answer the best I can. Thanks in advance for the help.
Old Mar 10, 2014 | 10:20 AM
jkeaton's Avatar
Sounds like still have a misfire......check engine light on?
Old Mar 10, 2014 | 12:56 PM
Akzle's Avatar
engine mounts or clutch chatter.
Old Apr 13, 2014 | 01:18 AM
doofusmagee's Avatar
run a compression check. a low cylinder can do that. maybe a burnt valve.
Old Apr 13, 2014 | 09:03 AM
Akzle, you're right. Engine mount.
Old Jan 5, 2020 | 06:00 AM
MRDIY's Avatar
One thing to look into is if the timing belt was changed and the oil gear timing mark is 180' out.
It is very easy to make this mistake. The down side is that you will have to remove the belt to check it out.
The timing mark should spin back to the other timing mark when you move it away slightly in
either direction. If you turn it away from the mark and it moves further away, then it is 180' out.
this will cause a low rpm vibration. I hope this helped. Keep us up to date.
Galanthighspeeder
Jan 26, 2020 09:19 PM
Galanthighspeeder
Jan 5, 2020 06:02 AM
ray_liota_2006
Aug 13, 2012 10:22 AM
rspedron87
Jun 16, 2011 06:52 AM
chris carter
Oct 12, 2005 12:40 PM
