2001 Eclipse GS Spyder P0170 code
Old Mar 18, 2018 | 08:10 PM
oscarrod73's Avatar
Default 2001 Eclipse GS Spyder P0170 code
My car has 150,256 miles. I need diagnostic help to find out why vehicle is idling rough, I am receiving code P0170. It stalls at start. After starting and idle at 2000 rpms, short term fuel trim is at 24 while long term fuel trim is at 6, according to scan tool. When I step on accelerator it feels like it should be running great but as soon as I let go accelerator go, idle goes back to around 678rpm and STFT/LTFT remain the same. I have replaced EGR valve, IAT valve, MAF sensor, O2 sensor, coolant temp sensor, and TPS. Nothing seems to help.
Old May 13, 2018 | 03:16 PM
Widgmaster's Avatar
Possible causes
Intake air leaks
Faulty front heated oxygen sensor
Ignition misfiring
Faulty fuel injectors
Exhaust gas leaks
Incorrect fuel pressure
Lack of fuel
Faulty Mass Air Flow (MAF) sensor
Incorrect Positive Crankcase Ventilation (PCV) hose connection
xgains
Jun 26, 2013 04:18 PM
menacemonty
Nov 12, 2012 10:45 AM
dsm1990gsx
Jan 24, 2009 11:16 PM
Natedogg89
Apr 13, 2008 08:54 PM
drakon
Oct 23, 2007 07:08 PM
