2003 Eclipse GS issues starting after warmed up
Old Nov 17, 2013 | 12:50 PM
wyatt0081's Avatar
Exclamation 2003 Eclipse GS issues starting after warmed up
I recently purchased a used 03 eclipse gs 2.4L 4cyl and been having issues even attempting to idle after i have ran the engine for a little bit. My car starts fine when it is cold but once it gets warm it doesn't want to start at all. the engine cranks, fires, but doesnt start to idle. At first i thought it was the spark plugs. Found out there was oil getting into the spark plug housings, replaced the valve cover gasket, and just recently replaced the ignition switch and still having issues. Once in awhile when im having this problem the car makes a sort of surging type noise.
If anyone has any ideas or has experienced this problem please let me know!
Thanks!
Old Nov 17, 2013 | 05:11 PM
mxmikie's Avatar
bad IAC motor ????
Old Nov 17, 2013 | 10:03 PM
wyatt0081's Avatar
But it idles fine when it starts up cold, Im thinking it has something to do with something overheating, all lights, stereo, etc. work when this problem occurs but wont start.
Old Nov 24, 2013 | 07:20 AM
Shab's Avatar
I think I have the same problem.
It started when I tried to replace my radio, I had some blown fuses and the clock don't even light up anymore.
Before that everythink worked out good.
Old Nov 24, 2013 | 08:43 PM
Akzle's Avatar
oil in the spark plug 'housing'?
New rings, vacuum leak, bad voodoo.
Old Nov 25, 2013 | 02:45 AM
Shab's Avatar
After few researchs, find out that the issue is certainly due to a deficient relay.
Have you checked all your fuses and relay first?
Old Dec 1, 2013 | 09:59 PM
wyatt0081's Avatar
iI checked all relays and fuses, thinking its the camshaft sensor, trying to find the correct one to fit my engine, been to all namebrand auto parts stores and even went directly to Mitsubishi and cant seem to find a sensor that fits. The sensor that they have for my engine; the bracket that holds/seals the sensor is bout 1/4 of an inch off. I dont really know where i can go to find the correct sensor. (Uses a code reader to find out its camshaft sensor)
mainelary
Jul 12, 2021 10:32 AM
mvoltage
Jul 31, 2014 03:34 AM
BroD
May 7, 2014 10:41 AM
colt_2030
Feb 16, 2012 05:38 AM
Chris154
Nov 12, 2007 10:38 AM
