AWD conversion, and Engine swap?
Old Apr 15, 2007 | 03:11 PM
Wingo171's Avatar
Default AWD conversion, and Engine swap?
I know there is currently a guy trying to convert his 3G to AWD, but he is using the rear cross member of a 2G and the transmission from a Lancer with the rear torque converter. Would it be possible to just swap the 2GGSX Manual Tranny and rear cross member? As far as the engine swap, I know the 3.5 L Diamonte engine can be put in our 3G but they say the DOHC model can't fit in our engine bay, and I'd just like to know how much extra room we'd need in our engine bay and in what areas to make this engine fit. Like do the heads cause a problem with not fitting between the firewall and radiator or is the engine too wide or what? Somebody please fill me in I'm getting all mad scientist over here ( I don't have the money for it , but please just humor me without being stupid and telling me the obvious that it'd be exspensive or I need lots of $$$ to do it....)
Old Apr 15, 2007 | 04:55 PM
Default RE: AWD conversion, and Engine swap?
I think the heads dont have room between the fire wall and radiator. Also the GSX tranny wont work cause it is mounted on the opposite side of the engine than the stock 3G tranny.
Old Apr 15, 2007 | 07:29 PM
Wingo171's Avatar
So how much more room would you need to squeeze this motor into the engine bay between the firewall and radiator. Now I see why the guy is using the lancer trannyand torqueconverter.Please answer the room question with actual numbers/measurements. thanks
Old Apr 15, 2007 | 09:32 PM
WPSpyderGT01's Avatar
when i get home.. ill give you a write up on the awd 3g's =D and what you can and cant use.
Old Apr 15, 2007 | 11:36 PM
Dusty Eclipse's Avatar
Wait, theres other AWD 3gs???
Old Apr 16, 2007 | 01:21 AM
there is ONE AWD 3g that i know of =D and my friend rob is actually doing his car right now.. which is a GS
Old Apr 16, 2007 | 01:32 AM
estraw's Avatar
i thought they only made the conversion kit for the 3g spyder.. idk what the difference would be but i thought they were specifically for that
Old Apr 16, 2007 | 04:34 PM
Wingo171's Avatar
Anybody got any measurements on the DOHC that won't fit in our 3G engine bay? Cause I want to know how much extra room you'd need to make it fit, cause I can cut the firewall in parts and expand that, and get a slim radiator.
rstoevo
Jan 20, 2013 10:47 AM
Imakeu Randy
Oct 8, 2012 06:16 PM
Davidevolv
Dec 21, 2011 06:47 AM
impreziv
Nov 7, 2011 07:01 PM
badass91hatch
Dec 16, 2005 02:37 PM
