Big idling problem
Old Jul 6, 2006 | 05:05 AM
KillerEclipse's Avatar
Default Big idling problem
ok, here is the background. I have a 2000 Eclipse GT Fed Spec, and this weekend i swapped out my stock plenum for a Diamante VRx plenum and i blocked off the EGR tube and put a filter on the plenum where the EGR tube would connect, i also installed RC 310 injectors.
Now the car is having trouble idling, and it doesnt feel like it is picking up as fast as it used to. I was thinking that the acceleration was bogging down due to the big injectors, but i thought that the idle should stay normal. I was thinking the idle might be messing up because the plenum no longer has an EGR connection but i could be wrong.
Anyone got any ideas. Thanks in advance.
Old Jul 6, 2006 | 08:53 PM
Sanguinius's Avatar
Default RE: Big idling problem
I'm going to say that if you've installed bigger injectors you may need a piggyback fuel management system. The ECU will be telling the injectors to open with the same amount of voltage that the old ones did but being bigger injectors it's actually opening more than the old ones. You're basically flooding out the engine is my guess.Not enough to kill it just enough to bog badly.
Old Jul 6, 2006 | 09:03 PM
i have a blue greddy emanage connected to the car with the ignition harness and the injector harness. But i dont really know how to tune it, do you have any tips on tuning thegreddy emanage or know any good websites? thanks/
Old Jul 7, 2006 | 01:31 AM
dont you need a laptop to tune the e-manage?
Old Jul 7, 2006 | 01:56 AM
yea i have a laptop and the support tool
Old Jul 7, 2006 | 02:04 AM
i would try and go here and see if you can get any info on it. I know they sell them, and probably use them in there 3g's. www.tearstone.com maybe shoot him an email and see if he has any good references
metalmtb
Nov 9, 2021 11:00 PM
Gstfat
Apr 30, 2008 10:32 PM
austinw23
Apr 24, 2007 07:57 PM
burnmyeyes
Dec 14, 2006 12:08 AM
Reddragon06
1st Generation
14
Dec 24, 2005 11:51 PM
