Cruise Control does not work
Old Sep 26, 2006 | 10:11 PM
chenfred's Avatar
Default Cruise Control does not work
[X(]The cruise will display in the console when I press the main switch but it will not hold the speed when I press set function. I followed the procedure to get the diagnostic code. There is none of the diagnostic code set in the ecu. My car is 3.0 manual transmission. Does anyone know where I should start to look at? Thanks for any help.
Old Sep 27, 2006 | 09:22 PM
chenfred's Avatar
Default RE: Problem fixed
The hose to the vacume actuator broken and caused the vacume leak. No wonder there is no error code.
Old Sep 27, 2006 | 10:17 PM
Sanguinius's Avatar
That was going to be my first guess a vac leak. Problem solved then and all works well?
Old Oct 3, 2006 | 11:45 PM
chenfred's Avatar
Yes, after replace the vacume hose it all works. If you cannot get the diagnosyic code, the problem should be vacume leak.
Old Oct 4, 2006 | 01:37 AM
Nubiebubie_GSX's Avatar
Default RE: Cruise Control does not work
I have a similar problem, but would having the clutch switch disconnected cause a problem with cruise control.
Old Oct 4, 2006 | 12:33 PM
93eclipsegsx's Avatar
it shouldnt because i have mine disconnected and i still have cruise control.
Gsteclipse22
Nov 22, 2022 04:13 PM
Pajoz
May 18, 2017 12:31 PM
salsomano1a
Apr 8, 2012 06:24 PM
doodman
Feb 4, 2009 03:10 PM
btv401
Jun 5, 2007 08:32 AM
