Daughter's 2002 heat/temp.guage issue
Old Dec 30, 2010 | 09:25 PM
LOWRIDER60's Avatar
Default Daughter's 2002 heat/temp.guage issue
While riding in her 2002 3.0 auto GT I noticed her temp guage would fluctuate between HOT and COLD and her heat would somtimes blow hot and cold as well.The car does not overheat though and otherwise runs ok. Would this be a sensor,thermostat, or something else causing this?
Old Jan 4, 2011 | 10:22 PM
jgbrules's Avatar
sounds like its low on coolant. have u checked the level?? if it is low, 2 common things leak coolant on that car. radiator splits at upper hose area, and the necks on the engine for the radiator hoses deteriorate and also leak coolant. again very common.
Old Jan 6, 2011 | 09:52 PM
Twoky's Avatar
That or it might be the thermostat or you might have a gasket that is not sealled all the way on your intake manafold I am having the same problem with my 03 spyder gt
walt
Feb 15, 2013 10:28 PM
livetoride20000
Jan 3, 2009 11:31 AM
LOWRIDER60
Apr 11, 2008 08:41 PM
OldSchool
Dec 23, 2007 05:05 PM
OldSchool
Apr 5, 2007 12:18 AM
