Driver side floor floods when A/C is on
Old May 24, 2010 | 09:11 AM
staceync's Avatar
Default Driver side floor floods when A/C is on
2003 Mitsubishi Eclipse Spyder
This just started happening, driver side (only) floor gets soaked when the A/C is running. Searching threads in this forum indicates it may be the evaporator drain tube.
Any idea how to fix this or point me in the right direction of a repair manual? I'm looking at the Haynes repair book.
Thank you for any advice!
Stacey
staceync@gmail.com
Old Jun 1, 2010 | 07:26 AM
It is the heater core. It is a common issue on these cars.
Old Jun 1, 2010 | 06:21 PM
Vonda's Avatar
I had the same problem last year. There is a link to the Clug3G site that has pictures as well as another link to posts that go into detail. You have to read through the posts to really get all the info.you need. If you look at my profile and find my posts( I only have a few) you will see it. hope this helps, it sure helped me and saved me a few hundred $. Much thanks to the people here and at Club3G for there valuable help.
Old Jun 2, 2010 | 09:15 AM
staceync's Avatar
Thank you for replying to my post, your links to the photographs were most helpful!
Old Jun 2, 2010 | 02:50 PM
Vonda's Avatar
Your welcome. A FYI make sure when your reading the posts it is in reference to your exact car. Some of of the posts are for 2002's and our cars are different. Also, there is a excellent service manual at Tearstone for free.
Old Jun 17, 2010 | 02:29 PM
staceync's Avatar
Default Update
I took the car to a local A/C guy. He cleaned out some debris near the evaporator tube, but noticed that the evaporator housing was cracked. He was nice enough not to charge for the cleaning, but the housing repair is going to be big $$. Floor still floods but not as bad. I am sweating out the hot southern summer until I can get it fixed.
Old Jun 17, 2010 | 11:59 PM
That's bull****. It isn't hard to epoxy it.
Pick up a wrench, you won't believe how much you'll save.
Old Jun 18, 2010 | 08:58 AM
staceync's Avatar
Default Epoxy
Sebba,
I'm sure an experienced car person could do the epoxy work. However, I removed the seats, and most of the console up to the dash trying to do this myself. Had no luck and took an entire day to put everything back together.
If you could post photographs of specifically what it is I'm supposed to be looking for it might be possible for me to pull out the wrench again. I also do not have access to a lift.
Thanks,
Stacey
Old Jun 18, 2010 | 03:18 PM
I don't own a Mitsubishi, so naturally I don't have to get greasy very often. You don't need a lift.
If you utilize the best tool available to you (tah interwebz), you'll find various articles steering you in the right direction.
Like this one: http://www.ehow.com/how_4521309_repl...i-eclipse.html
Simply find the crack (if visible), and seal it.
shebamookie
Jan 28, 2014 01:20 PM
shebamookie
Oct 11, 2013 12:36 PM
Peter1986
Jul 15, 2013 10:44 PM
bishigt_18
Nov 1, 2008 07:24 PM
kornvolks
Feb 12, 2006 01:09 AM
