Mitsubishi Eclipse & Eclipse Spyder For years, the Eclipse line has stood for cutting edge styling and performance at an affordable price.
Eclipse SX a/c leaking on driver's side floor
Old Sep 16, 2013 | 03:01 PM
shebamookie's Avatar
Question Eclipse SX a/c leaking on driver's side floor
Water is leaking from my a/c on the driver's side. I have a 2004 GS Eclipse and was told this is a fairly common issue from 2000-2005. A mechanic just blew out the line and thought it would be fine, it wasn't. My car flooded again. I called Mitsubishi and they said it is a $16 (#MN121314) part but with 5 hours labor it would be $616!! It goes between the evaporator case and the firewall and to get to it you have to remove the dash. Another mechanic suggested an "O-ring" or even a small hose on the nipple between the firewall and evaporator, would either of these other methods work? Any help would be greatly appreciated!!
Old Sep 16, 2013 | 03:42 PM
mxmikie's Avatar
Old Sep 16, 2013 | 04:15 PM
I don't understand your comment mxmikie?
Old Sep 16, 2013 | 06:20 PM
There is no such thing as an Eclipse 'SX'.
It's bull****, there's some crap in the system that stops up the drain. All you have to do is squirt some water up the drain hose an it'll come down. Some compressed air works too.
Old Sep 17, 2013 | 12:44 PM
Right, it's a GS. They alreay blew it out, it didn't work. Not sure what is bull**** but I clearly have no idea and am looking for help. Other options?
Old Sep 24, 2013 | 12:12 PM
Can anyone please help me???
Old Sep 24, 2013 | 01:16 PM
It's just a hose hanging down from the middle of the car.
Old Oct 2, 2013 | 03:34 PM
Thank you Sebba so much, but there is no hose at all, that's the problem. It's just flush with the fire wall, so water is going back into the car. Do you know what size/kind of hose I could use? Or would this so called O ring work?
Old Oct 11, 2013 | 08:35 AM
This was a complete waste of time, thanks
Old Oct 11, 2013 | 12:36 PM
Go **** yourself. You don't pay me for my time you entitled little kunt, so don't bitch when the answers you wanted weren't given. You don't even know what ****ing car you own! How about not being so ****ing lazy, grab a wrench and do it yourself.
I'm willing to bet you're female, just based on your special breed of entitlement because you're so used to getting everything you ****ing want.
EDIT:
Female from Chicago... what a surprise.
shebamookie
Jan 28, 2014 01:20 PM
3130
Jun 8, 2013 05:57 PM
Kptaylor
Jul 28, 2011 02:17 AM
staceync
Jun 18, 2010 03:18 PM
bishigt_18
Nov 1, 2008 07:24 PM
