Electrical Problem
Old May 1, 2008 | 11:28 PM
steezbro's Avatar
Default RE: Electrical Problem
ORIGINAL: Sebba
There is a fuse some place that went... guarenteed.
Someone told me once it might be a 100 watt or amp (idk what one) fuse in the engine bay that went out maybe. Could someone tell me what that looks like, where it is so i can check that? Thanks
Old May 2, 2008 | 12:05 AM
PoolhallJunkie777's Avatar
there should be a box of fuses under the hood. that would be the only place. i think it is on the right side but dont quote me.
Old May 2, 2008 | 02:26 AM
steezbro's Avatar
ORIGINAL: PoolhallJunkie777
ya i didnt see any 100 in there at all. idk if thats it, its just some guy that told me it could be it. does anyone know what 100 amp or watt fuse im talking about? Can you take any pics?
Old May 2, 2008 | 11:45 AM
Dusty Eclipse's Avatar
Uh... if any of the items you mentioned (door locks, cd player etc.) were provided with 100amps... you would have a significantly larger problem, lol.
Like Seb said... its likely gonna be a blown fuse... I dont have my 3G in front of me, but Ive had a similar problem and it was the fuses. If not, there could just be a short or something somewhere... Instead of checking the fuses by just looking at them, try replacing the key ones... such as the sunroof one and radio set of 2. Sometimes when the fuse blows its hard to see whre the "rip" is in the fuse.
Old May 2, 2008 | 01:03 PM
steezbro's Avatar
ORIGINAL: Dusty Eclipse
alright, thanks dude, I will be doing that today
Ill let you guys know later how it goes.
Old May 4, 2008 | 11:54 PM
steezbro's Avatar
Tried replacing all the key fuses, and nothing changed, same problem
Anymore ideas?
Old May 6, 2008 | 01:52 AM
steezbro's Avatar
how do you check fusable links? those are the ones in the colored boxes with the clear tops correct? could it be the ECU (thats the big black block thing in the engine fuse box? how do you check relays casue arnt those the black boxes that you cant tell if they are good?
poiz
Apr 25, 2006 02:26 PM
poiz
Oct 17, 2005 07:30 PM
Bakesale420
Sep 8, 2005 02:44 PM
9498jl
1st Generation
Jul 12, 2005 01:31 PM
HoloSkull
Sep 13, 2004 12:17 PM
