Fluctuating Idle...heat issue?
I have a GT V6 Eclipse. Bolt on Weapon R Short Ram. a Noisy Cannon Muffler. and I recently replaced the thermostat in the cooling system.
The problem that I am having is that while the engine is idling, it rolls up to 9000 RPMs and then down to 4000 RPMs. It does not seem to affect the car -- merely annoy the heck out of me!!!
Thank you in advance for your advice.
RE: Fluctuating Idle...heat issue?
Now the idle is worse and finally a CEL has come on...
P0455 came up twice...
The PCM has determined that a large leak exists in the evaporative emission control system
I have not gone under the engine to see where the leak may be coming out-- looking for loose bolts etc.
I appreciate any input you might have. THanks.
john196899
24
02-05-2021 11:07 PM
