Fluctuating Idle...heat issue?
Old May 27, 2006 | 12:51 AM
Eclipsor's Avatar
Default Fluctuating Idle...heat issue?
I have a GT V6 Eclipse. Bolt on Weapon R Short Ram. a Noisy Cannon Muffler. and I recently replaced the thermostat in the cooling system.
The problem that I am having is that while the engine is idling, it rolls up to 9000 RPMs and then down to 4000 RPMs. It does not seem to affect the car -- merely annoy the heck out of me!!!
Thank you in advance for your advice.
Old May 27, 2006 | 01:01 AM
93eclipsegsx's Avatar
Default RE: Fluctuating Idle...heat issue?
well i dont think you motor will rev up to 9k but its probably from 900 to 400 and flucating, its probably your idle air control that might be going bad.
Old May 27, 2006 | 01:52 AM
Evil1993Eagle's Avatar
Any cel's?
Old Jun 7, 2006 | 05:02 PM
Eclipsor's Avatar
Now the idle is worse and finally a CEL has come on...
P0455 came up twice...
The PCM has determined that a large leak exists in the evaporative emission control system
I have not gone under the engine to see where the leak may be coming out-- looking for loose bolts etc.
I appreciate any input you might have. THanks.
Old Jun 7, 2006 | 08:43 PM
Sanguinius's Avatar
Sounds like a vac line or EGR type leak...
Old Jun 7, 2006 | 08:52 PM
N/Teclipse's Avatar
another problem could be that the evaporative emission control system valve is stuck open.
Old Jun 7, 2006 | 09:38 PM
ORIGINAL: Sanguinius
Agreed. If the problem started when intake was installed chances are maybe somewhere in that area
Old Jun 20, 2006 | 03:14 PM
Eclipsor's Avatar
I misunderstood it to mean that there might be a leak in the exhaust...
Are there any tricks to finding an EGR (what does this stand for?) leak?
Or a Vacuum line leak?
thanks,
john196899
24
Feb 5, 2021 11:07 PM
walt
Feb 15, 2013 10:28 PM
Akmikek
Sep 21, 2012 08:28 PM
LOWRIDER60
Jan 6, 2011 09:52 PM
redrum1er
Jun 23, 2006 09:00 PM
