How do you open the Halo Projector headlights
Old Jun 26, 2007 | 09:17 PM
Wingo171's Avatar
Default How do you open the Halo Projector headlights
Does anybody have a clue how I may open my halo projector headlights?
Old Jun 27, 2007 | 01:05 AM
Twizted3g's Avatar
Default RE: How do you open the Halo Projector headlights
you wanting take off the plastic housing?
If you are then the best way ive seen so far is to bake the whole housing for approximately 20-30 seconds in the oven at or around 250. Then take a flat head screw driver and take pry them apart. If you hear cracking or its not coming apart you might have to put them back in for 10 seconds or so. Put them back together with a high quality glue and a cylincon to make a seal so you dont get moister on the inside.
Old Jun 28, 2007 | 07:00 PM
Wingo171's Avatar
Thank you very much kind gent, the job is completed YAY!!!
Old Jun 28, 2007 | 11:09 PM
Twizted3g's Avatar
yah have any problems?
Old Jun 30, 2007 | 11:18 AM
Wingo171's Avatar
Getting them open was the hardest part, but I think i'm going to try using a clear silicone and try to pinch the housing back to the plastic cover to close them again. Pics will be coming soon...
Old Jun 30, 2007 | 05:50 PM
Twizted3g's Avatar
sweet sounds cool, but you definitely want to use some sort of sealant if not you will get moisture under the cover and that just doesn't look good.
Old Jun 30, 2007 | 06:49 PM
Dusty Eclipse's Avatar
You did this to replace the 194s??
redturboeclipse
52
Oct 3, 2019 04:17 PM
SERPENTOR
Jul 24, 2015 12:19 AM
carid
Jul 16, 2014 05:34 AM
Wingo171
Jun 14, 2007 01:38 PM
whitestallion10
Feb 10, 2005 11:53 AM
